No oil drops at all. Just some smoke when running. My hose goes back to the front of the fuel tank and is open to the atmosphere also.
It is when I did the CCV mod I plugged the hole in the plastic coupler instead of the 4X4 pipe.
No oil drops at all. Just some smoke when running. My hose goes back to the front of the fuel tank and is open to the atmosphere also.on average if all the ps engines were not leting any oil out of the ccv nobody would do this to keep the boots from blowing off the intercooler tubes. as far as the smell I agree just dont believe the lack of signs of oil.
I hate to derail any further but the oil on the CAC boots is from the oil vapor from the CCV. If you do the CCV mod you will notice a slight coating of oil inside the hose but VERY little if any oil accumulation to drip. Just don't point the hose directly at anything and the vapor will stay airborne.So wear does the oil in the inter cooler tubes come from? has to come from some wear. If the smoke isnt smoke and is actualy vapor I might belive it. still think oil is going some place. if its a vapor and can build up on the walls of ic tubes means it can still build up under the body.
http://guzzle.rbmicro.com/ccv1.html
http://guzzle.rbmicro.com/ccv.html
if i was going to do it that is how I would. to make sure that their was no low spots to get build up in the hose it self and to ensure no oil leaking. or to start making the seals leaking from building up a pressure. Even if you emptyied it once a year and only got one once or so it would be worth it to me. thats all Im realy getting at. Besides I think I made this get way off from the origanal subject and let it get back to it.
I ran a 3/4in ID, 1in OD clear water hose for my ccv mod so I could visually see how much oil I am losing. I do not notice a major oil trail draining down the inside of the hose. Sure the inside of the hose is coated with oil vapor and I'm sure it drips a small amount of oil every once in a while, but I definately don't see any puddles under my truck.on average if all the ps engines were not leting any oil out of the ccv nobody would do this to keep the boots from blowing off the intercooler tubes. as far as the smell I agree just dont believe the lack of signs of oil.
Same here :fordoval:I ran a 3/4in ID, 1in OD clear water hose for my ccv mod so I could visually see how much oil I am losing. I do not notice a major oil trail draining down the inside of the hose. Sure the inside of the hose is coated with oil vapor and I'm sure it drips a small amount of oil every once in a while, but I definately don't see any puddles under my truck.
X2Same here :fordoval:
or just not do it all. Or will you guys try to convince my Im loosing hp from not doing it. :swordfight: havnt lost a ic boot yet and dont have a smell to wory about.If you do it like everyone else the only thing you should notice is the smell.
Come on Bill you know you want to do it! We did it on all of our Powerstrokes. Just get a piece of 4" PVC or steel pipe to install in place of the stock crank case intake exit. You'll flow alot more air!or just not do it all. Or will you guys try to convince my Im loosing hp from not doing it. havnt lost a ic boot yet and dont have a smell to wory about.
What a girl........or just not do it all. Or will you guys try to convince my Im loosing hp from not doing it. :swordfight: havnt lost a ic boot yet and dont have a smell to wory about.
lol :bowfast:What a girl........
:gayfight:
If you have 5 mins I'll show you how to do it.I probably won't do it until I loose an IC boot due to it!
