1 - 6 of 6 Posts
The Younger
I saw elite diesel has a twin hpop kit available. Now I know you you do not need it unless you have huge injectors like 340cc+. But I was wondering where do you hook up the lines to it from the engine?
The Unseen Mod
Well more then likely its gonna be tied back into the oil rails if you think about it. The point of having to pumps is to keep the pressure up.
The Younger
Yes but where would you tie it in too? Do you drill and tap holes?
The Unseen Mod
Rails ???? go look at a set of 04.5 newer rails dont need to drill or tap. Everyone setup is different.
Banned
Old thread, but I know the kit from Jesse Warren (Warren Diesel) ties the output from the auxiliary pump into the test port on on the stock HPOP cover, and has the pickup in the bottom of the oil pan.
1 - 6 of 6 Posts
