1 - 9 of 9 Posts
Hey Guys,
Bought a 4 position Tony Wildman chip for a buddy of mine for his 02 SD F350 ZF-6 CC dually.
He does have an edge in and have turned it down to "0" on the power setting. Wanted to leave the edge in just for read out of Boost and EGT.
Cleaned the contacts with PCM in place, upon install get an engine light and the glow plug light stays on? Have un-installed chip for now any suggestions would be great. One more thing how do I get the PCM right out so I can do a better job of cleaning?
Thanks to all,
jrc
Crazy Talk
when i have not got them cleaned good the glow plug light would not come one and wouldn start.
All done now
Hey Guys,
Thanks to all,
jrc
Pull the PCM out and clean the contacts good. If the problem repeats, remove the tuner completely. If it still repeats, call Tony, he will fix you up.
Thanks guys,
Have been looking for a "How To" for removal for the pcm on this truck....have undone the harness bolt under the hood and disconnected the plug. removed the two bolts holding the pcm plastic frame on the inside close to the park brake peddle i.e. furthers from firewall. plastic frame will still not let loose.....what am I missing here to get this dang thing out??
thanks.
jrc
<<< THE GAUGE WHORE...
Is the chip tuned for a 02? If its tuned for a 99-01 the WTS and Glow plug lights might stay on or not come on...
Thanks CSIPSD,
Had requested the tunes specific to this truck, provided the VIN (but not engine build date)....mmm guess I should check that as it might be on the shoulder of dates. Or rather it would be the PCM build date??
Still have to pull the PCM right out and do a good cleaning of connacts as it would appear not to have had a chip previously. Does have an edge would that make a differents?
thanks for comments guys..
jrc
Premium Member
with the edge being a programmer it would just plug into the obdII port, my guess is that the contacts on the pcm arent clean enough.
on a second note jonathan from beans did a ts chip install in the recent issue of diesel world, step by step photos.
Village Idiot
marty had a good video on pcm change.
must be in the library somewhere.
Discussion Starter #9
Thanks guys,
Have looked around here and was not able to find adequate info of me...ahem on the "other site" guys put me onto Dieselmanor website diections and will get at it tomorrow. It was the 10mm bolt and nut on the inside that had me messed up as I didn't know they where there. After removing the 7mm ones things would not fully dis-assemble and was wanting to put the axe in there and mix it up a bit...heh heh.....should be gtg now....thanks again.
jrc
1 - 9 of 9 Posts
