1 - 4 of 4 Posts
Well I have an 11 F450 Lariat, about a two months ago I park the truck to go into a store. When I come back out to start the truck the steering is dragging and the airbag light is on.
So I replaced the clock spring and now the self cancelling turn signals don't function at all. Everything else in the steering is working fined, including all other electronics.
I can't seem to find out from anyone where that function is performed? In the clock spring or some other area of the steering system.
Any help is greatly appreciated
There is a sensor behind the clock spring, steering wheel rotation sensor. It plugs into the Steering Column Control Module. It is used to cancel the signals. We had an 11 F550 at work signals wouldn't cancel, turns out they forgot to install that part from the factory. 3F818 is the basic part #, your local dealer parts dude should be able to show you a picture if you tell him to enter that number as a basic.
1 - 4 of 4 Posts
