i knew you could i was on a couple of other fourms an the said the fuel pump its self had a adjusting knob i couldnt find it on mine so i came here you guys know your stuff
The mechanical fuel pump on the PSDs is a rwo-stage unit. The pressure is not adjustable other than at the fuel pressure regulator (and raising much above 70 psi isn't good for the rest of the injection system). The Hydraulically-actuated Electronically-controlled Unit Injectors (HEUI) basically act as their own high pressure pumps. Want more fuel, you need modified injectors and programming to match. Cheers!
No factory switches. The 'switch' that some refer to is likely a switch for a pcm chip (which controls electronic tuning for fuel, oil, etc) that they have on the dash. In that reference, yes, you can 'turn it up'...
This will not "turn up the pump" but will increase fuel pressure to the injectors..... Do a search on shimming the fuel regulator, also called the BB mod. Inexpensive to do and may make your truck run a bit smoother. As noted above for significant change you need to get a chip/programer and injectors, with supporting mods like a down pipe and gauges.
