1 - 2 of 2 Posts
Now there is an easy solution to replacing the underachieving
factory Ford 6.0L Powerstroke diesel with a complete bolt-on kit. The Turbonetics 6.0L turbocharger pedestal kit
is available in a variety of configurations to allow consumers to custom choose the power levels they want to
achieve.
The mounting kit comes with both a pedestal to mount the turbocharger securely to the engine and also an
adaptor flange that bolts to the inlet of a standard T4 4-bolt turbine flange to fit perfectly to the exhaust inlet
v-band connection. No modifications are needed to connect to the factory exhaust plumbing to the turbocharger.
Made of high strength stainless steel and precision TIG welded, the pedestal allows direct connection to the
turbochargers oil drain flange for strength and proper fluid flow. As shown in the attached image, all bolts, studs,
gaskets and miscellaneous hardware is included as well as full installation instructions for an easy install.
Offered in three separate packages, Turbonetics allows its customers to have full customization:
1. Turbonetics Ford 6.0L Powerstroke Pedestal Only:
Part Number: 21653
2. Turbonetics Ford 6.0L Powerstroke Pedestal Kit:
Featuring all necessary flanges, hardware and fittings
Part Number: 11313
3. Turbonetics Ceramic Ball Bearing turbocharger & Pedestal Kit:
Includes pedestal kit (11313) & ceramic ball bearing turbocharger (11470-BB) - Turbocharger upgrade requires
the use of custom tuned programmer or ECU re-flash.
Part Number: 11580
The Turbonetics turbocharger upgrade means Ford 6.0L Powerstroke owners no longer need to sacrifice slow
throttle response (ie. turbo lag) by bolting on makeshift parts and can eliminate the lazy stock units spool-up.
Turbonetics Patented Ceramic Ball Bearing turbo provides both fast spool-up for quick acceleration and increased
airflow to help keep EGTs down. Low exhaust gas temperatures (EGT's) are extremely important when towing
and when the Turbonetics turbo upgrade is combined with the NEW Spearco Ford 6.0L (PN: 70057) Intercooler upgrade
you have a win-win combination of more power and increased efficiency. Spearco Intercoolers routinely drop
intake temperatures by 150 degrees. That means an equal temperature drop in exhaust gas temps to tow longer,
harder and heavier payloads. The increased airflow and cooling efficiency of the bolt-on Spearco intercooler
assembly is highly recommended to be used at the time of turbocharger upgrade to properly cool the increased
boost pressure and inlet temperatures.
Please PM me for PSN member special pricing.
1 - 2 of 2 Posts
