1 - 6 of 6 Posts
Apparently I'm missing something here . . . All the up pipe bolts out & the 2 bridge clamp bolts out & these things won't lift out. I've tried by hand & using the lifting bracket from FoMoCo. They will wiggle very little, am I missing a mounting bolt somewhere?
The HP sits on 2 locating dowels, which can be holding things depending how corroded they are. Spray lots of penetrating oil on them. you might need a small pry bar under the base when lifting on the bracket.
1 - 6 of 6 Posts
