1 - 20 of 21 Posts
hey guys i got a couple questions concerning turbo flutter. i pretty much know how to get rid of it im just not sure on which method is the best. i was thinking about a ported shroud compressor housing or a WW or possibly both since the WW is supposed to make spool up quicker. what do you guys think is the best way to go?
Old Yeller, REBORN
get a 38r, its a actually performance upgrade that will cure surge.
Until you put 238's with it. LOL
The ported housing is the best. A WW is just a noise maker. Together, they will sing for you. Louder than a 38r in my opinion.
will the ported housing spool up faster than stock? and is a x wheel the same as a WW?
PSD
they are a replacement wheel for a 94-97 powerstroke. call them what ever you want. they don't do to much.
Old Yeller, REBORN
I can't remember if it did or not.
Also, you will lose a pound or more of boost with the WW(X wheel).
gonna get the ported housing. thanks for the help guys!
Old Yeller, REBORN
college kid dont have to much money to spend right now. but i get what your saying, wish i could afford that monster. just figured i would take care of the problem before i damaged the turbo and then in the future replace the whole thing
Village Idiot
for stock sticks i would do the wicked wheel..then save for the 38r, then injectors.
DAMN THATS HOT!
Im looking at getting my brother something for his SD. Since WW arent that expensive I was thinking it would be a good gift. He has a 01 SD that is bone stock. What benifits would he see from a WW. Even if it sounds better thats enough.
Also are these the same wheels that are on the OBS turbos? I have my old turbo and was wondering if you could just swap the wheel out?
Discussion Starter #14
Then spend 100 on a ww. How much can you tow when you're in college
when i go home on the weekends and work i typically am towing farm equipment from tractors to a trailer load of 15' christmas trees. so i actually tow quite a lot and my turbo has been taking a beating.
The wicked wheel cured mine. As stated, it's alot cheaper, and will probably fix the surge, so you can save your pennies for a real turbo.
FORD..THE ROCK CRUSHER
WW will spool a tiny bit faster but flows a little less air..it moves the surge just a little bit higher in the RPM's..makes the tubo whistle a lot more if you have an open air filter like the 6637.. the WW is a stock wheel for the OBS trucks, so yes you can pull one out of an obs and put it in the SD...
DAMN THATS HOT!
Awesome! Thanks for the info!
Village Idiot
When you tow do you hear a pssht pssst pssst sound like a pressure cooker...if so that is surge.
The guy with the stock truck should see improvement if he tows at all. A great gift. If he can use a wrench.
Your brother would LOVE you if you got him a 38R! Here is a pic stock/38R. Everyone loves pictures. 38R stopped all my surge issues.
My 38r used to surge so bad that I could actually hear the insides of my boost gauge slamming around over the turbo whistle and surge noises. That turbo ended up costing about $1 per 10 miles I got out of it. It died after about 15,000 miles and it's not rebuildable. I'd either go with the cheap mods or go with a t4 mount turbo. Turbo options are virtually limitless with that setup.
1 - 20 of 21 Posts
