1 - 17 of 17 Posts
truck looses boost going at crusing speeds and then comes back to life once i get in to it harder. I can hear what sounds like air escaping, but like i said above if i get into it harder it boosts up.
Any ideas??
Discussion Starter #2
It will go away after about 30 minutes most of the time.
Need more power!!
Is it cold out? Is the truck up to operating temps? Sounds like EBPV. Do a search on it and you will find a bunch of stuff.
yeah it was below 30 out when it was doing it. it seemed to get better once it ran for 30 minutes or so.
even while crusing?
Premium Member
If it does it while cruising then the ebp tube is prolly clogging up, but at the same time it's job is to close to aid in engine warm up.
so there is no fix for it? and i should be fine to just run it
Premium Member
Fix is to gut it as in removing it.
BTW Just seen your location, my grandparents use to have a place there before my grandpa died. Used to be up there every summer for the fair and 4th of july, miss it up there.
so i dont have to have a EBPV?
yeah we have the best fair around. It is definitely a fun place to live
Premium Member
Nope, I unplugged mine then deleted it once I was able to.
I remember being up there before there was a walmart or a home depot and a lot of other things up there.
is there a delete kit i can buy?
Yeah its definintely. i remember that also. back before the tanger mall got its make over. when the glens used to be by M55
Premium Member
I can get you a price on a non ebpv turbo pedestal, you will then just need a small pipe plug to plug the hole where the rod is for the valve.
I havent been up there in a few years, kinda hard since my grandpas passing. I'm only a few hrs south of ya over by flint.
Discussion Starter #14
Ok yeah let me know on a price. Then I can put the plug and a snap ring in there. So I doesn't back out.
I have family down in Durand holly linden and davison.
Premium Member
PM on the way.
I'm actually in Lapeer, check out the regional row section for the next get togethe. Next one up is in January.
check your Y up pipe from underneath the truck.....mine's leaking from the joint...same thing as your's....lost of power....i can hear blowing nosie from under the truck.
Discussion Starter #17
ok thanks billc i'll check that in the day light see if i can see a crack
1 - 17 of 17 Posts
