1 - 14 of 14 Posts
Whats the best turbo set up i can put on a 6.0 for the money ? I have ARP head studs EGR deleat with 4" turbo back pipe with bullydog downloader. Any help would be welcome. thanks
The Unseen Mod
Get an SCT, and a VGT-SR
Scab
Why the SR?
The Unseen Mod
Because its just above stock, will run fine n clean up the stock injectors, but its smaller then the garrett n vgt-ss.
Scab
I am asking because I have one and I got it for the reasons that you stated above. Anyway I would just buy a stock replacement instead of a VGT SR if I was doing it again.
I ran an industrial 62/70 for a little with stock injectors. stay with a vgt with stock injectors. there is a bit of a deadspot around 50 or so on the non vgt. elite's sr, garrett powermax, a stock replacement or 03 turbo are all good options for stock injectors.
Found out that the turbo is not bad just gummed up with carbin they said something about the main vaine in the turbo is stoped up can any one tell me how to fix this problem?
The Unseen Mod
Take it apart and clean it.
Damnkids Motorsports
and then get an SCT and get rid of the bullydog.
I got a Garrett PowerMax turbo and love it. Slightly larger than stock '03 turbo and brand new, not a rebuild like most aftermarket VGT upgrades, cheaper too.
What kind of improvements are you seeing ?
EGT's , boost psi, MPG's
I am thinking of getting one.
Where did you get it from?
Thanks
Right now I'm running stock programming still, so it is just a hair laggier than stock, but not bad. Cruising on the highway I'm seeing 50-100* lower EGTs and 2-3 lbs lower boost. This is due to the larger exhaust housing and bigger intake turbine, it moves more air at lower pressure, which helps make it more efficient as it gets the air it needs with less back pressure. MPGs seem to be up about 0.5-1 mpg, but I haven't put enough miles on it to be sure. I got it from Aden at GOS Performance.
Discussion Starter #14
I had the turbo cleaned and it worked good for about a week and now if acting stupied again ! any help!
1 - 14 of 14 Posts
