1 - 13 of 13 Posts
Hey all. For those of you guys running pillar gauges, are you running turbo gauges, or are you using the stock gauge in the cluster? I dont want the stock gauge to be dummied, and it goes all the way to 40 PSI...
thanks guys
this was my theory. Thank you Ford!!! Im planning on EGT, Fuel pressure, and... uh... I thought tranny temp, but sounds like in other posts its not needed!
i guess thats right, i just really like to see my actual numbers not just lines and guessing, just my .02
For your first 3 get pyro, fuel pressure, and coolant temp. The stock coolant gauge is a joke...
Coolant is a good suggestion. Most of these stock gauges are a joke, if you ask me anyways.
I was told by a forum member that fuel pressure is a must; as important as EGT gauge. Sounds like a winning combo.
Why are the fuel pressure gauges so exspensive compared to the pyro and others?
I thought the same thing when I bought mine, but it is worth it. These trucks will run for a while with no fuel pressure.
You know, I cant afford to buy a new powerstroke motor. And if I could, I would buy a 7.3 and drop it in this chassis and cab... perfect truck. Anyways, I cant afford a new PSD, so I will end up paying for the little do-dadds that will helps me prolong the life of my daddy-stroke...
oil temp is good to know. I would get ect , eot, fuel press. Edge insight is a good place to start and get a fuel pressure to mount somewhere.
I've got a boost gauge on my pillar. I also have plans in the future to add three more gauges though.
Or if ya just get a wild hair up yo azz you could do this......
If your running a tuner and give hell from time to time then a Tranny Temp would be a worthy investment...Next to watching EGT's those trans temps will ride pretty high
Not Winning.
I don't have a factory boost gauge, but i love knowing exactly what my turbo is doing. Oh, and the factory tranny temp gauge is a joke, i would highly recommend it if you're buying gauges. A coolant temp, oil temp or hpop gauge, and a fuel pressure gauge are in my near future
cshsrh, i like the four pod pillar. I thought they only made those for the OBS. I like the four pods because I would like to have an air pressure gauge for hen I end up getting airbags for the rear, I can monitor the air pressure, and not have some awkward single gauge somewhere. The top mounted gauges dont look so bad either...
1 - 13 of 13 Posts
