1 - 14 of 14 Posts
tur4.JPG i bought the brushes at home depot 6 to 7 bucks they worked great i put a little electric tape around them to keep them from spreading apart i used a wire when i cleaned the vain fins so they wouldnt fly across my garage you dont want to loose them caution wear safety glasses you dont want a peace of this wire flying into your eyes
Most use the 3m pads since they'll produce a smoother finish, its what Ford recommends as well. A light coating of never-seize is a good idea, you should clean off most of what you have applied though. I apply it and then wipe the bulk off leaving just enough to color the surfaces.
yea i had to wipe some of the antiseize off when i reasemble it it didnt meet up flush 3m pads yea they might be better but i have to do a couple of 6liters these were cheap and did ok
How long can i expect to spend tearing out my turbo and cleaning it? can i do it in 6 hours with a full shop of tools
should be more then able too
Is it possible to get the turbo out without lifting the cab?
very much so no need for cab removal to get turbo off
Nothing inside the turbo you need, but you can get the turbo mount kit which has seals and o-rings and new bolts for like $8.
Haters Gonna Hate
do u guys remove your alternator when u pull your turbo? cuz i couldn't for the life of me get mine snuck past the damn thing, it would wedge on the wiper cowl and the back of the alternator
Diesel Sled Head
Never pull the cowl or the alternator. Just takes the right angle to weasel her out. The 03s I always remove the heat cover on the exhaust side. No need on the other years. About 3-4 hours total job time including cleaning.
i always move alt to one side just leave the back left bolt in but loose and swing it a bit
1 - 14 of 14 Posts
