So for a set of 238/100% or possibly larger, what would be the recomended turbo? Moded H2E, Sledgehammer, or any other suggestions.
GQSSB can be offered for the OBS running 2" plenums and no intercooler or for the OBS with intercooler. Kit is supplied with the required i/c pipes, up-pipes, pedestal, downpipe, y-pipe, and oil feed/drain lines. The only thing that might need some modifing is the drivers side I/C pipe to make it fit your current intercooler system. As the pipe that would be supplied would be for use with the Hypermax intercooler system. Also, the specs on the turbo would allow you to run in the 2.6 class.I dont really know what any of the specs mean on turbos... So your just throwing numbers at me unless someone would like to explain it...and I Like the GQSSB so far since its about the same price as the modded H2E while flowing more air... BUt I dont like how it looks like I have to buy the entire Kit to make it work. Im about to install my intercooler and stuff already. So If I get the GQSSB what all would need to be modded to make it work? Pedistal, up pipes, intercooler stuff? Im clueless.
