1 - 3 of 3 Posts
All,
My day keeps getting better as I find more stuff wrong with the truck. I now find my turbo is on it's last leg. The wheels haven't hit the housing quite yet, but play is at the outside of the service limit and due to a screwup with the air filtration system, the leading edges of the wheel are damaged/chipped. So now where do I go from here? Can the rotating assembly from a later 99-2003 SD fit into the housings (comp, turbine, bearing) of the 94-97? Are the wheel trims the same? I don't know if Garrett individually balances the components and then balances them together? Due to the fact I don't know, I really don't want to just replace the comp wheel and put a rebuild kit in it for fear it will shake itself apart down the road. Any thoughts?
Cory
How many miles on it? What year? Would you be willing to meet so I could take a look? I'll PM you my number.
Cory
1 - 3 of 3 Posts
