1 - 9 of 9 Posts
My buddy just called and he is working on his 05 f250. So along with everything else wrong with his truck he was taking it apart and when removing his turbo he hit a wall. The bolt on the backside of the turbo mounting it to the pedestal is stripped. He can't fit a drill or extractor back there to get it out and can't reach the rear pedestal bolt to just remove the pedestal and turbo at the same time. Any suggestions?
cut it off
It's on the backside he can't get anything but a socket back there to touch it. He had tried heating it and even just breaking the head off but nothing is working.
hack saw or a small recip saw
or a die grinder grind the head off it
Will try and will update after. Thanks for the help
if he can hammer a 6 point socket on it with some swivels and some extensions should be able to get it off if not your gonnna have to cut it good luck
Yeah, those Turbo Sockets from sears can remove a piece of Pipe if needed.
Also leave that back bolt out, it's not needed.
D
1 - 9 of 9 Posts
