1 - 10 of 10 Posts
Hello,
I have 2001 F-350 7.3l V8. What do you guys recommend for Tune, Cold Air Intake, Turbo kit, and Injectors??
Thank you
K
What are your uses for the truck and what is your budget? Much better options than a 38r these days.
Project Shamu
Do they even make Tymar intakes? Haven't seen those around in years...
My budget $8,500 Max. I want to tow better. I’m just looking for an exhaust break.
If you plan on swapping the turbo and want a exhaust brake, i would suggest looking at the dps turbonator with the vgt.
Administrator
I wouldnt run an exhaust brake on the stock valve springs. For towing 238/80's are way to big.
6637 filter
Full exhaust.
Php hydra
6.0 trans cooler.
And a good set of gauges.
If you want bigger injectors and turbo. I suggest some 160/0's or 160/30's. As for the turbo I would do a kc 38r but you wont have an engine brake. In my honest opinion it's not needed. If you dont upgrade the turbo a new compressor wheel from kc turbos will fix the surge and get some better boost. Or step up to a compressor wheel and turbine combo.
1 - 10 of 10 Posts
