1 - 5 of 5 Posts
I have for sale a TS Respeed. It will adjust your speedometer so it is correct when you had bigger tires and/or change gears. It is very easy to install. I bought it and was gonna use it but decided not to put it in. It will work on any 1992-2006 F250 or F350. It costs $300 new and I would like to get $250 for it but I will take offers.
owner/president
Been curious about the respeed/truspeed,but havent had time to check into them,does it connect to the ABS? and also do you have to return your trucks computer back to stock to set tire size then redown load your costum tunes?
Discussion Starter · #4 ·
Yes on a 99-06 Ford it would hook into the black/gray wire coming from the ABS. I dont believe you have to do anything with the computer at all as far as custom tunes go but not 100% sure. Like I said I never tried to install it but I did read directions and it didnt say anything about custom tunes. You can get on TSPERFORMANCE.COM if you want and read more about it. It is brand new still in original box.
1 - 5 of 5 Posts
