1 - 7 of 7 Posts
Just bought this chip week ago from guy on here. The first setting seems stock setting. 2nd setting seems like slight bump in power idles raised up a 100-200 rpm. 3rd setting adds lots of power/very quick throttle responce but truck idles at 1000rpm. 4th had check engine, wait to start light come on for a sec or so. 5th idle raised to 1200 rpm and last seemed same as first setting.
Heres how guy posted sell:
I just bought a new ecu and need to sell my TS 6 position chip for the early 99 pcm. Has 60hp, 80hp, 120hp, 140hp, high idle, stock.
Thanks
His trucks early 99 auto, mines early 99 6 speed
His pcm xle4 I believe his post said. Mine awa3. But figuted only difference is his was auto an mines 6 speed so should work?
are you positive both are early?
He said his was a early 99 auto. So only difference is his was auto an mines 6 speed
Member
Auto and stick tunes are different I believe. I have seen other with problems
when the chip is burnt for a different trans.
DIFFERENT TRANS DIFFERENT TUNE SET UP...
I've heard that you can run an auto pcm in a standard but not a standard in an auto (no shifting) Not sure about the chip. I think I would get some new tunes. Maybe one of our fine tuners will jump in here. Good luck.
Already sent chip to kt performance to get my pcm code put on and 6 new tunes ;)
1 - 7 of 7 Posts
