1 - 5 of 5 Posts
Polevault821
I'm thinking about running 6 LEDs to show what position my chip is in I would mount it to my pillar but trying to figure out how I should do it I have a small amount of knowledge on electrical due to taking classes I would use 6 lumex single LEDs I'm not sure the wiring on a TS I would imagine it is live wires coming in to the switch I would run a rectifier diode so that power can go to the switch but can't back feed and run a 2 pole 6 position switch run the power to light the LEDs will use a resistor and more diodes on the relay to the chip does anyone think this will work and also am I over thinking this
Super Moderator
Super Moderator
If you use a 2 pole switch there shouldn't be any effect on the chip itself. It's two different circuits on one switch. How do you want to do it. One led per position or 1 led for one position and 6 led for the 6th position.
1 - 5 of 5 Posts
