1 - 4 of 4 Posts
<- Sums it up
The instructions say to tap into the ABS module pin 16, grey/black.
Where/what the heck is this ABS module? I don't even know where to start to look for this thing...
Thanks
The ABS module is under the battery on the front driver side.
The easiest way to get access to the wire is to remove the left front fender well liner. With that done, you will have easy access.
<- Sums it up
I take it there is only the IDM and the ABS module in there to choose from?
Thanks,
The IDM is under the wheel well back by the door.
The ABS module is all the way up front. There is a bundle of wires that runs off of it back towards the cab. The wire you need is in this bundle.
1 - 4 of 4 Posts
