1 - 4 of 4 Posts
Wasn't consistently getting the WIF light so i took apart the HFCM and got alot of gunk out of it. But not now it'll crank but not start...any ides:doh:?
Let's assume it went back together properly...
Did you follow key on/ key off procedure?
actually I think I know the problem...in the upper left corner is a black plastic piece that holds a float and spring...where can I get a detailed diagram of how that goes back together?
try this when you re install the cap use some oil on the o ring turn on the key shut it off go in the motor crack the upper filter open until you hear all the air release some fuel may spill dont worry i did this three times and my 6 started up shook a little then ran fine
1 - 4 of 4 Posts
