1 - 8 of 8 Posts
i was on my way home last night when it started dropping RPM and then just shut off and won't crank back it hits ever now and then. i checked my number 22 fuse and it's fine just replaced the filter like 500 miles ago. the fuel bowl gets fuel but the valve on the side has nothing if you push it in a drop of fuel will come out and that's it nothing else besides air and yes it has diesel in the tanks and when cranking it bellows gray/white smoke and smells like raw diesel please help i can't check anything in the dark and would like some direction to go in the morning thanks for the help in advance
Demon Dually
You have a bad fuel pump. Relace it and clean the screen between the fuel bowl and fuel pressure regulator and replace all the small hoses between the pump and fuel bowl and you will be good to go.
and where is the pump located? i'm confused as to it's location
well i reckon i need to get to work thanks for all the help guys
to late now almost done with it but i look at it as i rather do it now than later
1 - 8 of 8 Posts
