1 - 6 of 6 Posts
Recently my 97 7.3 wont go into gear while its running but when its off it will and also will grind when trying to put it into reverse. If I start it in gear and drive I can change gears but its really hard. It also came as an auto and was manual swapped I was wondering if this is just the pressure plate/clutch disk or something else. Any help is appreciated thanks
Premium Member
check the fluid level in the clutch master cylinder, it may be something as simple as low fluid level.
Premium Member
(y)
1 - 6 of 6 Posts
