1 - 6 of 6 Posts
My truck is a 04 and I was driving down the road and lost oil pressure on the dash and truck died. I had loop oil so I pulled motor and studded it and did warren injectors and torque converter. I also found my hpop had puked its ball bearing. I just tapped and plugged the hole. I know have everything together and the truck still will not fire. Do you think I should have replaced the hpop? I have no way of scanning it so is there anyway I can test it. Anybody in south eastern Ohio with a diagnostic reader want to make some extra cash let me know. Thanks for any help.
Fixing Broken Stuff
You really need to scan it, guessing gets real expensive.
First thing to look at is ICP, then FICM voltage and sync.
When I did My rebuild, I neglected to fill/prime the HPOP OIL RAILS. They were full of Air , thus the Injectors would not FIRE.
After several long cranks it fired and ran.
I then found a steep Levee locked in 4 Low and drove up the levee and then backed up it to "Purge" all the air out at higher RPM.
Fixing Broken Stuff
I replaced ficm about 2000 miles ago.
That doesn't mean it's still good, you should look at the voltage. I've seen a G-B reman FICM that looked good on the data stream but would not start the engine.
I've tried to time it how long it takes to get a 6.0 started with the rails and oil cooler dry, doing approximately 30 crank inter-volts it usually take 3-4 minutes of cranking to get a 6.0 started. And that with a battery charger on high trying to keep the battery's up.
1 - 6 of 6 Posts
