1 - 6 of 6 Posts
Ferd Power!
Hey guys my buddy just bought a 97 obviously powerstroke anyway it doesn't seem to see normal temps I've had 2 trucks and they would both sit about the o in normal on the gauge this truck gets to the first line before normal and stays there, is that fine?
Sent from my Autoguide iPhone app
STILL LEARNING
Those "gauges" mean NOTHING other than that is has temp. They are just a switch
i got a 203* thermostat and mine goes up to the "A" then comes back down to straight up and down. befor that mine would sit between the n and o. never sat lower than that unless it was -25 degrees or colder outside.
Fixing Broken Stuff
I have two 97's one needle sit in the middle of the "O", the other truck the needle sits on the first line, and I put a 203 stat in it.
the oil psi is juston off a switch. the temp is a real gauge o is about 195*
1 - 6 of 6 Posts
