1 - 20 of 20 Posts
Fellas,
I have done new springs (X codes), new ball joints, energy suspension sway bar bushings..
I can't figure out why my truck sits 5/8" lower on the drivers side.
My buddy has damn near the same truck as me except V10 and his is off by maybe half of that...
Any suggestions? :confused:
MINK
its just the powerstroke gangsta lean....is your frame true? tire presures eqaul? what do all four corners mesure?
I can tell you the tire pressures are the same. Not sure about the frame? Do our frames get tweaked easy?
Driver Front: 41 1/8"
Pass Front: 41 5/8"
Driver Rear: 40"
Pass Rear: 41 1/4"
And the reason for the front being higher is I just did front shackles today and this really made the "gangster lean" stand out.
Attention Whore
Is the tank full ?
MINK
its really so close I wouldnt worry about it....if your truck has been in a accident then its posible the frame is a butt hair off....and its gangsta leanLOL
peterbilt'in
fuel tank level... i notice mine reaching into the tool box before a fill up... then after... afters a lot easier to get to the box.... harsh on the wallet!
Going Crazy
make sure you back srings arent broke and missing a leaf.... mine has done that twice and each time leans one way or the other just a tad
I did heck on level pavement.. :poke:
And actually the fuel light is on, which means when its full, this should be worse :mad:
I have heard that ford makes a shim kit to correct this problem.. Maybe I'll look into it?
Also I know my driver front shock is pretty much shot. But I doubt this would have anything to do with height. Correct me if I'm wrong.
Shock shouldnt have anything to do with it. Shocks just absorb movement.
nobody likes a quitter
I have an easy fix... are you into fat chicks?
McLovin!
Don't blame any of that on the tank being full or the shocks blown. That is the dumbest thing I have ever heard. Sounds like something the chevy owners would say. It's all in the springs.
Discussion Starter #16
Easy man...
If you say its all in the springs.. Would you say the rears are worn? Like I said, I just installed X's in the front about 4 months ago.
Lovin the Tuna
Easy man...
Brand new? Have you tried switching sides that the springs are on, see if the sag follows?
Driver side sits low on mine. 1/2" You don't need a tape. Most people would never notice, but i see it.
me too, just dont point it out and no one will ever notice
1 - 20 of 20 Posts
