1 - 9 of 9 Posts
My truck gave me a miss a few days ago when I started it up in the morning. The next day it did the same thing. Now whenever I start it up in the morning it dies instantly. It does this repeatedly until I give it some pedal and get it a little warm. While doing this the engine runs and misses trying to die several times. It takes about 5 minutes to get it to where it will run. Once I get it running it runs just fine for the rest of the day. Until it sits overnight. Whenever I am cranking it in the morning I get smoke so it is getting fuel.
Anybody run into this before??
What's the outside temperature when you're cranking up in the mornings?
IV been gettin some of the same it only does it if I don't plug her in tho
Outside temp is maybe 60-65°. All the glow plugs and gpr are new and factory ford stuff at that not the cheap bosch stuff.
I was tempted to plug it in and see if it made a difference, but , it's just not that type of issue. I have 3 OBS trucks and have had my share of GP problems and this is different.
:whs: maybe it's got a code stored that will lead you in the right direction
It gave me a CEL today and stayed on. It gave me trouble as usual this morning and even gave up some later after I had been driving it awhile. However, this morning when I got the no start I did some checking. The HPOP res was all the way full to the fill plug when I checked it. I have to pull the sensor that is on top of the res to check this one b/c it has the allen head and it is stripped. Whenever I put the sensor back on and hooked it up the truck started right up and gave me no problems from there.
I have an AE , but , my laptop is in the shop. I need to call and get it back so I can run some data stream. I havent had time either , but , I need to hook up my HPO gauge I had made so I can see if I am getting enough oil to even start it .
What is enough psi to start 700-800?
1 - 9 of 9 Posts
