1 - 10 of 10 Posts
so i have a 02 f250, heres the problem.... i just had a new tranny put in last week and worked great around town... headed for work out of town (3hour trip) and 2 hours into the trip, the truck quickly cuts in and out, like if i turn the key on and off real fast... so all the start up lights come on for a second and then it resumes driving... it will go for 5-10 miles (sometimes more) and then it will cut out again... i can seem to hold 60ish, more and it cuts out more... i held 55 for quit along time till i creeped higher and then she cut out again... anything i should check before i head home??? would cps have symptoms like this??? tps??? thanks....
Discussion Starter #2
i should add, it was hard to tell if a rougher road had more issues cutting out or not.... is there any wire connections on the tranny swap that could cause these symptoms?
id check the trans connection, the truck wont run with it unplugged it just may be loose. has the truck been in for the cps recall?
yes the update was done, but i am running the international purple cps now... if they go can they cut in and out maybe? i did crawl under and wingle and push the wire harness connectors together alil more...
when a cps starts to go out it will cut out for a split second. throw the one from ford in it and see if it stops.
ill swap them when i get home, since i left them in the garage... i hope i can maintain 55 without any issues... i leave tomorrow....
what did u find out?
1 - 10 of 10 Posts
