1 - 6 of 6 Posts
OBS junkie
The Superdutys brakes run off hydro boost. If you have a PS pump issue your also going to have a brake issue. Like said before, check your fluid level.
Still learning
yea its prolly the pump then, like stated earlier the PS pump also does double duty with brakes, i had the same problem and it was the pump, it is a B*&CH to get off and replace.
1 - 6 of 6 Posts
