i just replaced the fuel pump and figured my fuel pressure was low. The new pump did not change and the highest fuel pressure I can get at the bowl is 34 psi but it consistent drops to 20-22 psi under load driving it around my neighborhood.
I also thought the tune I have on the truck might help. (Currently I have a edge evolution cts3 running the performance tune) tune or stock did not change pressure or make the problem go away.
When the truck doesn’t completely shut off I can only get up to about 1100 rpm until I either get normal power back or it dies. I’ve checked my pcm, Ficm, and Ficm wiring harness from top to bottom and now nicks or exposed wiring. All fuses and relays are good. I have an adjustable blue spring kit from XDP on its way to at least eliminate the low fuel pressure issue. I also have the receipt from ford when the previous owner got new stock injectors put in back in October. I understand this is a lot of info but this is everything I have and know of on the truck. Any help is greatly appreciated.
