1 - 10 of 10 Posts
tries to stall when put in gear cold
Ihave checked the icp (550 ish @ idle) when I put the truck in reverse to get out of the driveway it pull the motor down to 450 or so and feels like it want to stall and has a few times. I changed the ipr since i had one here and have unpluged the icp with no change . I had changed the icp out a few months ago . could the new icp sensor be acting up? .when i rev it cold it will act the same wiht the idle going to low.or ?? or could it be the convertor or trans?? no codes with AE.
Discussion Starter #2
I assume if my AE is reading the psi that the sensor is working correctly? i see no changes runing wose when I unplug it.
ok did some more testing .when it tries to stall the icp does raise ( from 550 to 700) so I am sure the hpop system is ok. so now i am thiking either the convert or something in the trans is messing up?
so far I have swapped out
the acel ped assembly &
computer with no changes.
the check ball was removed from the return line dropping the back pressure from 30 to 10 psi.( per brian @ BTS)
Anyone??
I find when I am going down the road and put it in neutral the rpms drop to 500 and come back up. but no codes.
fuel pressure low at idle?
Have the transmission checked out..... When they start to fail, it can cause the exact symptoms you have.
Discussion Starter #9
Yea I think it is the converter, or solenoid pack Trans temps are ok . wants to stall when cold and just pulls idle down after that when coming to a stop.intill it gets warm.
Fuel psi is 60
Have swapped out the PCM
IDM
IPR
Ipc
Tps
with no change
Just for kicks I swapped out the cps no change
I can hear the motor loading up like when you would be letting out the clutch on a manual. So and the icp comes up so I know the motor is trying to compensate.
1 - 10 of 10 Posts
