1 - 20 of 31 Posts
· Got 'Er Did
2000 F250 Auto
between shifts it has started to slip (can watch the rpms go up)
and goinging into overdrive it will do the same thing and sometimes shudder before shifting
no CEL no overdrive light flashing
tried callin' transmisson shops they say i would have to bring it in from them to check it out
but i dont want some home town shop tearin' it apart and charging me for non quailty parts
i hope i can get some help advice from here so if it is convertor or vb related i can order from the big boys and put good parts
thanks
tanner
· Registered
2000 F250 Auto
thanks
tanner
Put Autoenginuity on it and monitor input and output shaft RPM.
· utah get me two
your self employed,and like to spend money,go see john wood,if you set it up in advance,he will, pull,re-build and re install your box wile you watch in 1 day,and show you why his box is better,and he is alot of fun to be around......david
· Got 'Er Did
Discussion Starter · #5 ·
well went to move it yesterday and it slipped bad:lame:
pulled the stick and its burnt....bad:lame:
time to make some phone calls!
· Got 'Er Did
Discussion Starter · #7 ·
ATS on the way
i went with them because they have a dealer right in Billings and thats where i am soon to reside
so if i had any issues my shop wouldnt be a few states away
· Registered
ATS on the way
· Got 'Er Did
Discussion Starter · #14 ·
went with the 650hp version
i know i lot of people said bts or john wood
but i wanted to stay as close as i could and this way i am able to give atleast a home town shop (G & J diesel) some business for installation
· Registered
Read the fine print then. Make sure that they will stand by you and not toss you out because you have mods. I know from reading that JW and BTS don't.
You can have BTS and it is shipped to your local facility or where you wish. I picked mine up and the Fedex Freight shop and brought it to my local shop where the tech installed it for $200 cash.
ATS Automatic Transmissions carry a 3-year/150,000 mile warranty. This warranty shall not apply to any automatic transmission that has been improperly stored or installed. This warranty shall not apply to misapplication, improper operating conditions, accidents, or neglect. This warranty shall not apply to an automatic transmission that has been improperly repaired, maintained and/or altered by the owner or his agent/tech. This includes, but is not limited to the following:
1. ABUSE resulting in broken, fractured, or sheared shafts/gears; damaged clutch packs/bands (except as identified in “Clutch Pack Failures” above).
2. Damage to the front pump due to mis-installation or misalignment of the torque converter.
3. Damaged gear train due to insufficient lubrication as a result of:
a. Low fluid level
b. Improperly serviced transmission
c. Modifications to cooler system that is not approved by ATS (i.e.: external transmission filter, restricted cooler lines)
d. Non-updated snap-in connectors in cooler lines (Dodge Specific: 94-98.5 must be upgraded to screw-in cooler lines)
4. The use of other than Factory or ATS TCM/PCM programming.
Pay special attention to #4
· Colorado PowerStroke Club
What? Has BTS fallen from grace?
Bite your tongue.:gun:
No BTS hasn't fallen from grace in the least bit. I have not seen any unhappy JW customers either, and if closer, well then.
Sounds like BTS and JW treat their customers much the same way.
· Registered
I love my BTS!
· Got 'Er Did
Discussion Starter · #19 ·
off to get the new trans tomorrow:D
loaded up on the trailer
this is the second time my ford has been behins the old man's dodge:lame:
· All done now
That's gotta hurt. I had to get pulled out of the mud, 1/4" by a Chevy 1500 once. All my truck would do is sit and spin, we used a 6' dog leash to pull me out.
1 - 20 of 31 Posts
