1 - 20 of 22 Posts
How much does it cost to install one st a shop?? I would buy it my self and just need to know how much labor would be. Thanks
We put the FU! in FUN
It's a fairly simple job and requires little mechanical ability. Just do it yourself and use the money you save to fill your tank up and go for a cruise
owner/president
Don't forget the in./lb. torque wrench.
Edward Scissorhand WanaB
Wow its really that easy.. thanks Btw how many quarts does a stock tranny take??
Almost 18 quarts
IIRC to do the valve body you will need about 8 quarts
Discussion Starter #9
How hard is it to seal the pan back?? i heard you have to use silicone???
I did my valve body separator plate at work, on a gravel driveway, laying on a sheet of plywood. It is a some what messy job with the trans. fluid dripping all the time. Keep plenty of paper shop towels handy for your hands and tools and for drip spills.
No silicone needed.
IIRC Remove pan, remove thumb filter, remove trans.filter, locate valve body, remove, install new valve body, torque and install filter, install thumb filter, clean pan and surface, install pan, torque pan bolts, refill with correct trans. fluid.
There is a flush procedure in the Transmission forum section at the very top.
WOW again very easy people are stupid when they talk about stuff they don't know.
Discussion Starter #14
Thanks for everything!:ford:
:doh:
No biggy I know I sometimes just click the last page thing and go from there.
I was following the thread earlier today and remember reading the post about the install instructions on ITP website but did not remember seeing the link to it:doh:
Well he shouldn't "F" up the install now seeing the install link is posted 4 times now.
Pan gasket is reusable, no silicon needed. While you are at it drain the conv and blow out the cooler lines and have 18 qts on hand. Mine took a little over 17.
Discussion Starter #20
how do i drain out the Converter?
1 - 20 of 22 Posts
