1 - 3 of 3 Posts
hi guys
my 04 f350 6.0 tranny has been acting up a bit all stock tranny but i'm waiting to install innovatives custom tunes. sometimes when i put it into reverse there is delay before it'll go into gear then bangs into gear and then bangs again and also may have a delay going into foward gears as well. any ideas what may be causing this? thanks in advance john
04 f350 crew cab dually 4x4 6.0 auto 4.10 gears,arp studs,banks cold air,4'' magnaflow,ddp modified vg turbo,90hp injectors,waiting to load eric's tunes
00 lightning 450rwhp
there is/was a recall for this common 03-04 problem..its a problem with the reverse plantary. Might wanna call your dealer up and ask them about it..might be able to get it fixed for you.
talked with my dealer and the reverse recall has been done already and he said with all the programming i've been doing the tranny doesn't know what to do. i've just loaded eric's custom tunes and the tranny is working great now.
1 - 3 of 3 Posts
