I completely agree. That chart is way off. I have always gone by the 100* above ambient temp rule.That chart is complete BS. Ignore it, it has NO relation to reality.
Normal temps for a 4R100 is 60-100°F above ambient temp. So 150°F in 50°F is normal.
I disagree with that, too. Modern transmissions can run all day long for a long, long time at 220°F.Once you start to get above 215*, transmission life will begin to deteriorate.
Do you consider the 4R100 a modern transmission? Or are you referring to the 5R110 and newer?I disagree with that, too. Modern transmissions can run all day long for a long, long time at 220°F.
Mark, I have a V10 powered F53 Motorhome GVWR 18,000 with a 4R100 trany. I replaced the stock smallish trans cooler with a 2005 F250 6.0 Cooler which is almost 3X the size. It runs now nominally at 110 -120. Even pulling a grade it does not break 130. Is that too cool? Is there any downside to running it this cool ? Will the torque converter lock up as designed under these conditions ?That chart is complete BS. Ignore it, it has NO relation to reality.
Roger on the Clamp,won't be doing that.A clamp on the cooler line should restrict the flow enough to reduce the lube flow to the rear of the trans, which will result in a destroyed transmission. Don't do that!
Is the line with the temp sender the one from the front or rear of the transmission?
