1 - 1 of 1 Posts
Hey everyone, I decided to go ahead a go with 3/8 transmission lines.....the bypass line and the 2 3/8 lines. The problem iam having is the rear fitting for the new line did not go in well. I pulled it back out because it started to go in real hard. When i removed it their were some metal shavings. Has anyone ever have this problem? Iam going to find a tap and die that is the same as the fitting my question is if i run it in the side where the fitting goes how do i get the metal shavings out of the hole? Any advice would help...Thanks
1 - 1 of 1 Posts
