1 - 20 of 20 Posts
· Registered
Well, my truck isnt shifting the way it used too with the new added power, it revs up instead of shifting, here is my question.. I have been told that a valve body will help me out quite a bit, I cant afford a full trans build yet, I can afford a tc, vb, and whatever it costs for the front pump. My ts chip is acting up and going back to the stock setting on me(running in 100hp setting then check engine light and back to stock power I go), So I will be getting a new f5 from Jody, So I can have him burn it for whatever route I decide to go. I am getting a valve body at bare minimum. Should I get a 6.0 cooler? I would like to hear what all of you have to say!! Thanks
· Registered
Well, I can give you my personal experience which may or may not help at all.
I replaced my torque converter with the updated "triple disk" one from Ford.
It is NOT the 6.0 converter, but it is supposed to be triple disk, only difference being a thick front cover and lower stall speed for the 6.0 converter. Otherwise the same.
I have a FTVB, don't really like the way it shifts but they are quick and firm, that has saved my trans a lot of slipping.
I also added a magnefine inline trans filter.
If your converter is not dying yet, I would add it BEFORE the coolers, to save it from being polluted if something does happen to the trans.
I truly believe this is why my trans is still together. I'm somewhere in the neighborhood of 375-400 I like to believe, definitely over 350 no matter what, and it's still living.
As far as the cooler, I would NOT do it unless you are having temp problems.
· Laces Out
for how cheap a 6.0 cooler is, and with a lifted truck, i would get it if you can find one for cheap or on ebay...i got mine brand new for $125...never gone over 170 on 37's.....worth it in my book....
· AllYourBaseAreBelongToUs
I've encountered this problem at each major power increase that I've done. Always fixed it with a torque converter. First got a converter from BD which worked well. Then got a full built ATS trans with their 5 Star. I've been sending the converter back here and there to get it loosened up or tightened to work with whatever set-up I run.
· Registered
^^ I agree, a converter made a huge difference for me as well. Felt like a different truck. Actually pushed you in the seat when it locked, instead of just revving.
I would get an inline filer on there ASAP so the dying converter doesn't pollute the rest of the trans, plug up the coolers and overheat, etc.
Then get a converter in it if you can't do a full build right now.
If you're savvy, you could consider a DIY while you have it out. Cost savings is substantial.
· Banning Smut
I have had really good luck running a Suncoast convertor and a Transgo tugger kit........until a couple months ago. no issues at all for over 3 years.
Convertor held fine, but I blew up the OD planetary. (from what I was told, the OD I blew was aluminum and should have been steel). While the tranny was out, I went back in with a heavier planetary assembly as well as a billet input shaft from John Wood.
I'm guessing my tranny is holding 450? maybe...
All is well now.
· Taters #2 Fan
I run the 6oh cooler and mine droped about 30-40 degress. so I know its help the tranny live. hope in a month I will have my full built one in.
· Bill
I just orderd a ftvb for mine. I was curious when I go to get a dp tuner if I should get jody to leave out the transmission programming? I heard that raising line pressures electronicly can cause valves to stick or open at the wrong time, overall causing more wear and tear.
· Registered
You need to tell Jody what you have and he will tune it accordingly.
Line pressure is removed for the FTVB because it's a hard shiftin mother. Reason I'm getting rid of mine....
The trans needs at least stock line pressure for the converter, clutches, etc. When you have a vb that shifts so hard you have to pull line pressure, not ideal.
and that's coming from one of the experts in the field, not me.
I heard from a little birdie that Dennis at ITP will be sellin a bitchin valve body from a very well known trans builder soon. They will be setup for stock line pressure...
· Registered
Discussion Starter · #16 ·
Does it rev up on the shifts or is it after the shifts are made and converter locked?
It revs up before it shifts into the next gear, once the converter locks it seems to do pretty good. I would like it to last me about another year(4000 miles), then I will be able to pay cash for a fully built one. If it goes sooner then Ill just have to put one of my other projects on hold.
· Registered
Discussion Starter · #18 ·
nope, it used to bark the tires shifting 1-2, now it doesnt. it revs as far as 3400, then shifts and kinda slowley starts taking off. But, if Im running 50 or so and lay into it, it takes off pretty good.
· Registered
Do you have the part # for this? I need a convertor for the early 99
1 - 20 of 20 Posts
