1 - 11 of 11 Posts
ok my gauge never worked there was no sensor when i got the truck, i just put the sensor in and nothing. is the a way to test it or does anyone have installation instructions its an isspro gauge.
also is there a better place to place the sensor it screwed in to the trans perfect on the driver front part of the trans. i didnt see a place for it anywhere else.
thanks in advance :bowfast:
Clutz
check to make sure that it is wired up correctly one wire from the gauge goes to the sender, another to a ignition wire and another to a ground.
That helps ill check it this weekend.
Do you have the part number from the gauge? It should be printed on the gauge can (either directly on the housing or on a sticker). We have made many different types of trans temp gauges, this will help in ID'ing it. Otherwise, please post a close-up photo of the gauge.
Thanks,
Michael Pliska
Thanks,
Michael Pliska
it a ISP-R653
That number comes up as a pyrometer leadwire in our system. Any chance you could snap some quick photos of the gauge front and back?
Regards,
Michael Pliska
Regards,
Michael Pliska
ill get some pics when i pull it out, if i dont figure it out on my own
Busted Knuckles
As far as the placement of your sender that's where it has to go unless you want to drill and braze the oil pan.
1 - 11 of 11 Posts
