1 - 5 of 5 Posts
I was wondering you guys that have a manual tranny and are using a trans temp gauge where are you placing the tranny probe at on the tranny? Thanks Matt
I put mine on the fill it will be the top plug that you take off with a 3/8 ratchet you will need a #10 straight thread o-ring by 1/4 plug to go into it then a 1/4 to 1/8 adapter then your sending unit the best luck i have found around here is tompkins industries they hooked me up for under 3$
That's what I was guessing, but then I got to thinking is the fluid even going to touch the probe? It should only be filled to the bottom of the fill hole unless it splashes up onto the probe. silverpsd_06 does yours seem to be working fine in the fill hole? Thanks Matt
Discussion Starter · #4 ·
Is there anybody else using a temp gauge with a manual tranny? Still tring to get more feedback from my first post. Thanks Matt
Discussion Starter · #5 ·
no one else? :confused:
1 - 5 of 5 Posts
