1 - 8 of 8 Posts
blowin coal
ya so my tranny seems to be acting weak to me when im cruisin and barely give her throttle she drops down a gear some times when im coasting i can fell her down shift real hard so does anyone have exp with this
What else?
Neither of those make me think a tranny is getting weak, slipping or a delayed upshift would.
You still have stock gears in that don't you?
Dave
owner/president
Has it always been that away or when you installed those 38's?
blowin coal
38 were on there yes stock gears i believe like w0hen im rollin about 60 mph 2000 rpms i sometimes have to let off the gas for her to shift into overdive
owner/president
I'm not a tranny expert,but have you checked your fluid? I would drop the pan and replace the filter and since i would already be in there i would change-out the valvebody for a BTS or John Woods after-market valvebody.
Does your tranny shudder?
Former Ford Trans Engr.
That's the reason right there. It's going to always work this way with stock gears and 38s. New fluid and a filter won't help this at all. Either will a new valve body, or even a new transmission.
Sounds like it's time to regear.
1 - 8 of 8 Posts
