1 - 3 of 3 Posts
i have a 97 powerstroke with 123000 and my tranny is the original and it is shifting harder and harder as time goes on any info on what it could be i was think it is the valve body
Demon Dually
Is the O/D light on the shifter blinking? Is the engine light on? If either have you had the codes read? Do you have long upshift issues such as shift from first to second etc..? Are the shifts neck snapping or just firmer than normal? What color is the trans fluid? Does it smell burnt? Is the level correct? Do you see fine metal particles in the fluid? Does the engine rev up higher than normal before the truck moves? There are tons of possibilities with the amount of info you provided. Answer the above questions and we can go from there.
im no expert on these rigs but mine was shifting very hard when cold and would take for ever to shift when warm . . i flushed the cooler and trans and a new filter .and fixed it . mabe try a fluid and filter and go from there . if you have no o/d light. a cheap fix mabe !!
1 - 3 of 3 Posts
