1 - 3 of 3 Posts
Hey yall, i was hookin up to my trailer and noticed i wasnt gettin pwoer to my trailer lights and fuond out that the outlet in back of my truck aint gettin power to it. I checked the fuses under the hood and allt he fuses are good the number 5 6 and 7 for the trailer lights. I tested it and the box is getting power to the 5 6 and 7 slots. Could the relays on the right of the box need to be replaced? Any help is appreciated thank you.
Tony
Demon Dually
How did you check for power at the trailer connector? There are a few relays in the power distribution block and a few fuses. Check all of the fuses in the power distribution block first. The second to last relay toward the back(firewall direction) is for the trailer marker lamps. If you aren't getting any power back there however I would check to make sure you have a good ground at the trailer tow connector first though.
i checked for power at the tow connector with a test light. thanks for the help
1 - 3 of 3 Posts
