1 - 6 of 6 Posts
THE BFT
Looking for a set of gauges for my 01 SD! got a couple thing to trade couple big turbos a obs transfer case bronco rear fuel tank (new) for an obs. Just seeing what you got! Thanks
Here are the measurements on the chargers.
Compressor Housing .96 A/R
Compressor Inducer 82.88mm (3.265")
Compressor Exducer 126.84mm (4.993")
Turbine Housing 1.14 A/R
Turbine Inducer 128.23mm (5.048")
Turbine Exducer 95.27mm (3.750")
THE BFT
750kw detroit diesel gen. set it was running 2 on each side! gen had 3000hrs on it and was still running good at the time i removed them they never ran over 1800rpm and had pm every mouth
Ive got a set of guages i will sell you. pillar mount turbo and exhaaust temp complete with pod, wiring and exhaust probe. $125 for all.
1 - 6 of 6 Posts
