1 - 2 of 2 Posts
The truck is a extended cab long bed 2002 superduty 7.3. In a 4 inch traction block would I need the block with the 5 degree angle to it ? Also my truck has the top over load leaf, and i plan to remove it when the block is installed. It seems obvious, but will the u bolts for trucks without the overloads be long enough, if I order online?
Thanks
Aaron
With a long bed you would use a flat block.
If you are removing the overload, then the ones for trucks without the overload should work for your setup.
1 - 2 of 2 Posts
