1 - 9 of 9 Posts
Has anyone found a track bar that doesn't rub on the cross member with a 2.5" leveling kit?
There is a thread about the one from TGC rubbing and now I have found out the hard way that the bar from Fabtech also rubs the cross member....mainly because of the diameter of the tube.
I guess Ready Lift was onto something with the track bar drop bracket.....
Discussion Starter · #4 ·
Fabtech bar....if the diameter of the bar were smaller I would have a chance but I have nowhere near enough lift for this bar. I will prob end up getting a drop bracket and going back to the stock one.
Just grind a little bit off the cross member. My dads 2011 has an icon adjustable trac bar and it rubbed a little bit but after a small trim it fits awesome.
Discussion Starter · #9 ·
So you think caster is the problem? I have no idea what it should be set at or what it's currently set at. Anyone have any specs? I know I have about 1/8" between the bar and cross member but it makes contact over bumps.
Sent from my Xoom using AutoGuide App
1 - 9 of 9 Posts
