1 - 2 of 2 Posts
I used to have the icon 4.5 hanger/shackle kit with that comes with the track bar bracket and the drop pitman arm. When I got my 33" nitto's I went to a ICON 2" mini spring pack, the shop that installed the 2" spring pack left the track bar bracket and pitman arm that came with the 4.5" hanger shackle installed on the truck. Was this the right way to go or should the stock bracket and pitman arm be put back on with the 2.5" mini spring pack? Thank you.
Measure your axle on both sides, from the same point, Like the split between the fender and door to the center of your wheel, and if there is difference (like half an inch) than what you would probably need to do, is put your stock bracket on, and get a drop track arm bracket or an adjustable track bar. this will get the geometry back straight.
Pitman arms depend on the truck because of the sag, but alot of levels I have researched use the stock pitman arm.
1 - 2 of 2 Posts
