1 - 2 of 2 Posts
Road Hammer
Hello guys. I have a question regarding the (new to me) truck in my signature.
I have noticed since I got it a month or so ago that when accelerating in any gear/road speed that the engine pulls from idle to 1800"ish" RPM effortlessly, it only takes probably 10-15% throttle to accelerate up to speed when in this RPM range, as soon as it hits 1800, it's like a wall. It takes substantially more throttle application to rev past this. If I wait and shift/want to shift at any RPM higher than 1800 I'm probably using 35%+ throttle. I can hear the engine/injectors work a harder (get louder), but the engine RPM doesn't change much until you get to/past that 35%'ish throttle. If I stomp on it/full throttle, it seems to make decent power, it'll spin in 2nd (3rd of 6) and has what I assume is normal power for a 7.3 (although does feel a bit sluggish on the highway, in overdrive/6th). A friend following me says the truck smokes ever-so-slightly (a bit white) when I'm revving past that 1800 mark, regardless of if I'm accelerating hard or just casually accelerating at a higher RPM shift. I can see a bit of a cloud of smoke at night in car's headlights if I get on it.
Can anyone shed some light on my problem? Is this a normal characteristic of 7.3L (I hope not)?
I have searched and checked out THIS thread, but I'm still unsure.
Thanks guys!
EDIT - Not sure if this means anything, but I changed my oil 1300 miles ago (Shell Rotella) and it's still super clean. Engine starts like new, and I'm pleased with the fuel mileage. Has no problems towing or anything.
Road Hammer
Discussion Starter #2
Anyone?
1 - 2 of 2 Posts
