Here we go!
Look down here:
Find the PURPLE with the YELLOW tracer:
Run the wire from the wire-switch, switch-ground. Put mine here:
Easily reached right here:
Pretty simple, so i didnt run 20 feet of wire i followed the trans harness to the fenderwell. Found the right wire, used a lighter to burn off the insulation, soldered on the wire, siliconed it and taped it up. Then i poked a hole in the steering column boot and fed the wire in. Then hooked it to the switch's one terminal, then the other terminal to the ebrake pedal bracket. VIOLA! t/c lockup on command! :evil
so i have it installed and only seem to notice it working till about 30mphTo those who are confused as to whats going on here...
All you're doing to completing a "grounded" circuit manually, instead of waiting for the computer to do it.
scenario 1
If you were to just tap into the current wire, run it to a single pole, single throw (basic on/off) switch, and run that switch to ground..
You would be able to lock the torque converter whenever you wanted, but the computer would still be able to lock it when it wanted to as well.
scenario 2
If you were to cut the current wire, run the transmission side of it to a single pole, single throw (basic on/off) switch, and run that switch to ground..
You would be able to lock the torque converter whenever you wanted, and computer would have no say in the matter, and could never control it.
scenario 3
If you were to cut into the current wire, run it to a 3 position switch, and run that switch (2 outputs) back to the computer end of the wire, and the remaining pole to a ground...
You would be able to chose between either of the above scenarios. Where you could (a) let the computer do its job, (b) lock it up, or (c) keep it unlocked without allowing the computer to have any control.
That being said, most people want the first scenario.
Also, @josh_mangan, If you want to shrink wrap it (recommended), simply cut the stock wire, then solder/shrink wrap both cut ends and your new wire all together. (scenario 1 above)
Mine is the same way. Was told it was normal, its not actually "hot" search back through and find my post on itWhen I did a search on installing a torque converter lock up switch it seems that the purple wire with yellow tracer is the wire that controls lock up. It it supposed to be open, neither hot or ground, it grounds to lock up converter. Mine has full voltage until converter locks up then the voltage drops out.
Any ideas from the gurus out there, I am stumped on what to do....
The button locks out fourth gear (OD). The converter will lock up in third. with or without the OD OFF button.Isn't the button on the end of the shifter to unlock the convertor? Doesn't that defeat the purpose of using a 3 position switch to be either locked, computer controlled, or unlocked?
Compared to just a single pole switch, closed to lock, open for computer controlled, then just the shifter button for completely unlocked
Thantake a switch (single throw single pole) and run one end to a ground then take the wire from the other side of the switch and tap into a wire comming from the trans harness right under your drivers seat that is purple with a yellow stripe on it. use a clip on type wire tap. just dont forget to unlock it before comming to a stop, trust me i felt like a jackass. but it greatly improves transmission temp and economy around town. have fun!
Thank you Thank you thank you! I've been searching and searching and searching just for this simple explanation on how to do this. Thank you so much!take a switch (single throw single pole) and run one end to a ground then take the wire from the other side of the switch and tap into a wire comming from the trans harness right under your drivers seat that is purple with a yellow stripe on it. use a clip on type wire tap. just dont forget to unlock it before comming to a stop, trust me i felt like a jackass. but it greatly improves transmission temp and economy around town. have fun!
You are very welcome!Than
