You could, however the PCM already unlocks the torque converter whenever the brakes are pressed or you hit the manual switch on a trailer brake controller that is wired into the factory wiring harness.You can add a relay powered by the brake light circuit and have its contact (NC contact) open the added switched wire. This would open the switch wire when the brakes are applied and the brake light comes on for as long as you have your foot on the brakes.
