Yea i'd like to know what happens with this mod...?What exactly does this do?
It locks up the torque converter when you want to. Ever notice when you are slowing down, and the engine stops engine braking when you hit the brake pedal? That is the torque converter unlocking.Yea i'd like to know what happens with this mod...?
well for one thing it keeps ya from killin the motor while your trying to figure out which purple/yellow tracer to tie into.yeah dont worry i fixed it. plus that was the only purple and yellow wire in the loom i tied into. and why would i need to put it on jack stands? whats that going to help?
You can add a relay powered by the brake light circuit and have its contact (NC contact) open the added switched wire. This would open the switch wire when the brakes are applied and the brake light comes on for as long as you have your foot on the brakes.You need to disconnect the lock up switch when coming to a stop. It will be like a truck with a 5 speed and stopping without using the clutch.
The third connection is for the indicator light ground in the switch.Any one have a diagram? Pics? I have an illuminated switch I want to use and it has three prongs not two..
